PG (Professional Geologist) license for Civil engineers
Any civil engineer with a PG (Professional Geologist) license?. I would like to know how hard would be the requirements for CEs in order to sit for the PG exam.
I was wondering if there are some special requirements for CEs in order to get the PG license?
Please let me know. Thanks
RE: PG (Professional Geologist) license for Civil engineers
I just would like to know how difficult would be the paperwork.
I heard i will need to get a degree in geology and then get the PG license. Seems to be difficult. Maybe there are better options.
Are you sure you don't mean engineering geologist alike those described within the UBC (check out chapter 33)? A PE (in most states) can provide most of the services a geologist does, but not an EG.
I am sure it's the PG license. I didn't know the EG license exist.
Thanks anyways.
In California, there are some people with dual PG and Civil PE licenses. Most of them have both geological science and engineering degrees. I know of a person (not in CA) that started with a PG and then took some courses in order to qualify for the PE.
In some states, one can take the PE exam without an engineering degree. However, California for example will not let you take the PG without the degree in geology.
The legal requirement in California to take the PG exam states:
"graduation with a major in geological sciences from a college or university".
The engineering degree probably would not be acceptable, but some other geological science related degree might work. Check with the local state board before investing in any course work.
Some states also have special licenses such as engineering geology, although it seems you have your mind set on the PE.
