mineral water
mineral water
Can someone explain to me the reason for injecting mineral water in a power turbine generator ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: mineral water
Where exactly is the water being 'injected'? And what type of turbine are you referring to?
RE: mineral water
RE: mineral water
RE: mineral water
"The principal pollutants associated with gas turbines are oxides of nitrogen (NOx). Control strategies for NOx include water or steam injection and premixed burners as well as the post combustion control by installing a catalytic reduction unit which consists of reacting the NO with injected ammonia in the presence of a catalyst."
http:
Large electrical generator stators are normally cooled by water.
So Steam Turbine also needs demineralized water for secondary cooling [auxiliary equipment and some time the Generator itself also.] as marks1080 already said.
Diesel Generator [the motor] is also cooled by demineralized water.
