How to "pick many" in 2001?
Hi there,
Does anybody know how to pick many dimensions to modify a tolerance or to set the dimensions to nominal values at one click?
Oxana
Oxana
RE: How to "pick many" in 2001?
mapkey md @MAPKEY_NAMEModify Many Dimensions;\
mapkey(continued) @MAPKEY_LABELModify Many Dimensions;#MODIFY;#DIMENSION;#PICK MANY;
This will allow you to modify many dimensions at once.
Ed
www.geocities.com/edwinmuirhead/pro-how/
Oxana
It must be choosing commands that still exist "behind the scenes", although it may be disabled in later builds of Pro/E?
BTW - I first saw the suggestion for this mapkey on the pro-user email exploder - there's a lot more Pro/E tips available there...
Ed
Actually, the mapkey does work after all. I tried it again without any other special settings in config file, and it did work. I use 2002100 cut of Pro/E (release 2001). Good luck.
Oxana
Go into Commands and check under Drawings, you will find it there.
Steve
http://www.3dlogix.com
Dave
regards
Yogesh
