Plastic ring: ID vs. temperature
I have a plastic ring with a certain ID value at room temperature.
How can I estimate ID at -65 deg C? at 125 deg C?
Do I need to run FEA, or calculations, please?
Thanks.
RE: Plastic ring: ID vs. temperature
You need the co-efficients of thermal expansion over the temperature range involved, then do the very simple mathematics.
The co-efficient of thermal expansion will change over that temperature range. If the currently undisclosed plastic is fibre reinforced, the co-efficient of thermal expansion will vary considerably according to direction of flow when moulded.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Patprimer,
Thank you for explanation.
The plastic is ULTEM 1000, and I was lucky to get a single value of CTE.
I am currently using a simple formula, assuming it expands in both directions along the radius.
I wonder whether there are better ways to estimate ID.
Yes, it would be better to use a temperature-varying CTE.
The CTE will vary significantly over that temperature range.
The biggest changes will be as it passes through second order transition points such as GTT.
I do not personally have data on Ultem 1000. Ask Sabic for more detailed data.
Pat
for site rules
Patprimer,
Sorry, I dont know how to get to Sabic.
Thank you.
Sabic did return "0" to ULTEM 1000...
http://www.matweb.com/search/datasheet.aspx?matguid=578c0713b95d4db4a8d8c0c53a872ffb&ckck=1
This gives along and across the flow over a fairly wide temperature range, but not so wide as you require.
YOU will need to contact Sabic directly if you hope to get more detailed information
Pat
for site rules
To TVP:
Thank you for this link!
