Exhaust Ventillation
I've installed an exhaust fan in my crafts room(10 inch outflow), and venting through an outside wall brings paint fumes back into my home through the windows. I want to run piping underground about 50feet out,(easy to do here) and 10" pvc is too $$$. Can I connect from 10" to 6" without compromising the efficiency much?? The fan is a 2000 cfm running medium speed.
RE: Exhaust Ventillation
Try 3 @ 6".
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
Mike Halloran
Depending on your fan you may not get the flow you want if you have to run the duct 50 feet.
Could you turn the duct vertically and discharge it a few feet above the roof peak, using galvanized duct instead?
