Which flexible coupling is better?
I wish to measure the vibration of a motor which is connected (via flexible coupling) to a DC generator as load. I found two types of flexible coupling as shown in attached image. Which one is better for this application (to minimize the vibration due to mis-alignment)?
RE: Which flexible coupling is better?
Keith Cress
Bill
"Why not the best?"
Jimmy Carter
A tight fit to avoid unbalance is what you should look for.
Gunnar Englund
www.gke.org
What is the size and speed of the machine?
The one on the left appears to rely on a set screw to hold coupling onto the shaft. That tends to push the shaft off-center within the coupling hub which is not good (particularly as clearance increases).
The one on the right does not appear to have that set screw to fix the coupling to the shaft, one would presume that the dimensions ares such that when you tighten the the two halves together clamp onto the shaft, which is a good thing.
So if those are the only two choices I vote the one on the right. But Bill's concern is very valid imo. Also would seek out the advice of a knowledgeable distributor or application engineer. Users don't typically select couplings.
http://www.zero-max.com/productmain.html
Please kindly refer to attached image. In my current experimental setup, two couplings are used. One is used to connect the motor and the generator, another one is used between the generator and the encoder position. I think these couplings are "resilient" or "elastic" couplings. The rated torque and speed of this motor is 2Nm and 400rpm respectively. With this experimental setup, the encoder position reading (i.e. the relative "position" between the encoder reading and back-emf waveform of motor (a brushless permanent magnet motor)) is found to be not consistent. I suspect this inconsistency is due to the "not-so-perfect" couplings. I'm not sure this phenomenon can be refered to as "coupling's winding up" or "coupling's backlash". Please correct me if I'm wrong.
Therefore, I wish to move the position encoder to another end of the motor (as circled in the attached figure). I'm not sure if "clamp fixing" or "Set Screw Fixing" is better to be used with the position encoder. Do you think "Clamp Fixing" is good enough to hold the shafts and prevent "contact slip", for example between the coupling and the shaft of the position encoder?
I plan to buy one coupling which has a hole with diameter that matches the diameter of the position encoder shaft. If I'm doing so, then I need to machine a piece of metal to 'match' the size between the motor shaft and coupling hole.
Thank you.
Are you talking about several problems here? One being trying to minimize any vibration due to shaft alignment and the other between a phase change between encoder output and generator emf? Or do you think it is caused by the same problem?
May be let's forget about the vibration issue first.
Before doing any serious experiments, I need to align the position encoder signal to 'match' the back-emf waveform of the motor. Let's say the PM motor has a single pole-pair. Now the DC generator is operated as a DC motor that drives the PM motor. An oscilloscope is used to capture the back-emf of phase A of the PM motor. The out signals of the position encoder (i.e. A,B,INDEX) are fed to a microcontroller with built-in QEP module. The microcontroller calculates the rotor position (0-3999) and output a 12-bit data to a Digital-to-Analog converter (DAC). The output of the DAC is fed to another channel of the oscilloscope, and to compare with the back-emf as shown in attached image.
To align both signals, I need to add an offset value to the computed rotor position value (in microcontrol program) so that the THETA becomes zero. Several tests were done as follows:
[T1] PM motor was rotated in counter-clock-wise (CCW) direction. An offset value of "125" is required to make the THETA becomes zero.
[T2] PM motor was rotated in clock-wise (CW) direction. With the same offset value of "125", the THETA was found not equal to zero! After adjusting the offset value to "120", the THETA becomes zero again.
[T3] PM motor was rotated in CCW direction. With offset value of "120", the THETA was not zero. After some adjustments, an offset value of "128" is required to make the THETA to be zero.
Obviously, the offset values required to make the THETA to be zero in T1, T2, and T3, are not consistent! Therefore, I suspect the problem is due to the couplings between the PM motor and DC generator, as well as between the DC generator and the position encoder. Please comment if I'm wrong.
Thank you very much
Now the signal may be aligned with zero software offset.
But when rotation is reversed, the encoder output may be inverted.
Without knowing more about the nature of your offsets, we cannot say whether the difference between offset 125 and offset 128 is important.
You may have torque peaks upsetting the position but probably not.
Two suggestions;
1> Apply a torque to a sample coupling and measure the windup. Does the coupling windup corelate with the offset error?
2> Move the encoder to the other end of the motor and forget about load torque induced errors.
Bill
"Why not the best?"
Jimmy Carter
Are you running the same load (amps or torque) for each of the three tests?
Are the magnets secured tightly in the motor (or generator)?
To waross:
I use "software offset" method. In fact, the values "120", "125", and "128" were created for discussion in this thread. This phenomenon does happen in my real experimental setup, but I can't remember those exact offset values. But I can assure that the inconsistent position reading has caused several problem to my control algorithm, which depends very much on the rotor position to operate properly. Not only this happens in reversed direction, even in the same direction, different runs of experiment will also give different results and need different software offset values for the algorithm to work properly.
To BobM3:
The existing coupling is attached to the shaft (of position encoder) by "set screw". Three tests mentioned in my last post are open-circuit back-EMF tests, i.e. no-load is applied in the tests. Only friction load I think. In my opinion, the magnets are secured tightly in the motor. There is not magnet in the DC generator, which has both armature and field windings.
To electricpete:
Well, the tests mentioned in my last post are used to align the position encoder signal to match the back-emf of the PM motor.
To sreid:
I think I understand what "windup" is now. But I still do not really understand what "backlash" means. Would you please how the Zero-Max Servo Class coupling attached to the shaft and guarantee "zero backlash"? Using "set screw" or "clamp method"?
Thank you very much
I'm not quote sure what you are measuring. Is it the voltage produced on the wires of the generator? Or are you actually measuring the back emf of the driving motor?
Backlash is a "looseness" in the connection. Change the torque in magnitude or direction and there will actually be a movement between the shaft and coupling.
If you're referring to my experimental setup, the DC generator is now operated as DC motor to drive the PM motor. The terminals of the PM motor are left open, i.e. without connected to any load. The back-emf produced by the PM motor is measured and displayed using scope.
Now I understand what "backlash" is. Thanks BobM3. I think one of the causes to my problem is "backlash". May be I should consider using "zero backlash" coupling. But I don't know how this type of coupling can prevent "backlash" if the surface of the shaft is round and has not keyway. Interesting if someone can explain it. Thanks.
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
Clamp style hubs are generally prefered. Set screws mar the shaft and tend to loosen even if two are used at 90 degrees.
