Caesar II Run
Caesar II Run
Caesar II Run
Hi
i would like to know how to check run error. when i click batch run icon to analysation stress sometime program don't stop running
thanks
Pongsapak
RE: Caesar II Run
The "Error Checker" can be invoked from the "File" menu or from the toolbar (the button is just to the left of the "two running men" button).
If you start a batch run, and the system doesn't converge, it will run for a very long time.  You need to determine the cause of the convergence problem, and make adjustments there.
Richard Ay
COADE, Inc.
