Pump shaft and impeller
I am currently working on a project that involves specing out a bolt that would be used to hold an impeller to the shaft. I was wondering what are the forces that i should consider to spec out a suitable bolt. Thank you.
RE: Pump shaft and impeller
More detail needed.
wimple
rmw
By then I was long gone and I was not going back.
Bill
"Why not the best?"
Jimmy Carter
