Minimum Distance between vertical curves
Hi All
I have an Urban streets design of hilly area, the designer wanted to reduce the cost and followed the natural ground, with minimum cut and fill. As a result there are many vertical curves one after another. I couldn't find any Standard specification that determine the minimum distance between two vertical curves.
RE: Minimum Distance between vertical curves
There's no need for any separation as far as I know, and I've never seen any design criteria calling for one. Remember all vertical curves are in real-life are 25' long lengths of Tangent.
I have seen a lot of high end custom home subdivisions where maintaining natural terrain and existing trees were goals to maintain the "charm" of the area. This dictated narrow streets, lower speeds and minimizing cuts & fills. The posted speed limits ended up being in the 15-20 mph range (or less in some cases) with restrictions on tall landscaping adjacent to roadways. In these designs there were no restrictions on compound VC's and in many instances there were combined horizontal and vertical curves.
So first check with the local jurisdiction requirements, discuss deviating from restrictive standards and then apply public safety criteria and also try to find examples of existing similar designs in your area.
I have heard of mimimum lengths of vertical curves. Placer County CA for example, I think requires a mimimum 100-feet between BVC and EVC.
I think the most important factor for vertical curves is the horizontal sight distance. For crest vertical curves, the length would be dependent on design speed vs stopping sight distance (at what point can an object on the road be seen by a riders typical eye hieght)
For sag curves, the headlight sight distance and rider comfort control the design (according to my civil engineering reference manual).
Lastly, I think compound curves and spiral curves relate to horizontal curves, not vertical curves.
Regarding spacing vertical curves, I can't remember any specification which required minimum spacing.
