linkage mechanism
linkage mechanism
linkage mechanism
Hi
I need to design a linkage mechanism (similar to a four bar mechanism) but the command lever doesn't have to influence the movement of the final lever for the first 20 degrees.
I use a cam to do it but I would like to change it for a classic belcranks-rods mechanism.
Do you have a piece of advise ?
Thank you.
RE: linkage mechanism
The first 20deg. of the forward stroke only or the back as well?
peace
Fe
To save playing 20 questions please define exactly what you mean. Draw a graph of input and output, and tell us of any other constraints on the design. So far you've defined a sloppy 4 bar linkage.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
smile "sloppy 4 bar linkage"
Just love it. smile
peace
Fe
