Ground bearing pressure-retaining wall and reinforcement problem
I have been asked to design a retaining wall. I need to check the ground bearing pressure.
The retainiing wall is shown in the pdf
C35 reinforced concrete is used. Surrchagre taken as 10kn/m2. DOT type 1 slag taken as 18kn/m3.
How do i calculate the maximum bearing presure? The allowable is 100kn/m
In addition how would i calculate the reinforcement required? I am guessing that i will be minimum reinforcement.
RE: Ground bearing pressure-retaining wall and reinforcement problem
http://www.cmaa.com.au/pdf/MA51_E1.pdf
When in doubt, just take the next small step.
