Part parameter
Part parameter
Hi everyone !
How can I pick information in a part (.par) and display it in the assy BOM, like the length of an HSS or some thing like this
THX
THX
RE: Part parameter
These can be viewed and renamed, so in your example you can rename the variable for the length from something like V1234 to LENGTH (use Tools > Variable Table).
I tend to use upper case for re-named variables so that they are easy to see.
There should then tick the "Expose Variable" check-box and that will make it visible to the BOM.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
RE: Part parameter
Also if you double click on the dimension, you can then enter a new name in the dialog box in the upper left hand corner. Just enter name and then "ENTER". After you choose "ENTER" you think nothing has happened, it has happened..:)
Solid Edge V20
RE: Part parameter
RE: Part parameter
RMB on the BOM, Properties, Columns.
bc.
Quadro FX4600.
RE: Part parameter
Attached file has a couple of options.
bc.
Quadro FX4600.
RE: Part parameter
I just found your message, you posted it here instead of in my thread Surfacing Help.
I never would have thought of using intersection points and keypoints curves.
Thanks a lot!
