Microstructures etched in glass
I am interested in etching microposts in glass with an aspect ratio of ~1-2.
Can anyone tell me if these structures will be resistant to fracture or if they can be easily broken off the surface when scratched with a fingernail?
RE: Microstructures etched in glass
is the ratio height to diameter or diameter to height?
if the etching is purely chemical, the finish will be smooth/polished and posts will be as strong as the parent material,  failures will occur at "sharp" corners  which should be non-existent for your etching.
The aspect ratio is height to width and we would dry etch the glass to get sharp corners since these are needed for our application.
You might check with these people for assistance:
http://www.translume.com/
Harold
SW2009 SP4.0 OPW2009 SP2 Win XP Pro 2002 SP3
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
