Flow as the fluid water rise from a pipe end
Once I see a graphic and related formula to know flow by the heigth the fluid rising from a open pipe standing vertical its main axis .
Any had seen it?
Please route mo to it.
Thanks in advance
RE: Flow as the fluid water rise from a pipe end
P1 + .5*(rho*v1^2) + (rho)*(g)*(h1) = P2 + .5*(rho*v2^2) + (rho)*(g)*(h2)
P1 and P2 are equal and cancel. v2 is zero at maximum water jet height. h1 is zero since it is the reference level. cancelling terms and rearranging...
f(h) = (.5*v1^2)/g
assuming negligible frictional losses along pipe length
-Mike
Hi Mike , I get it , its the bernoulli theorem.
Thanks , you solve my day.
Mile-02
