How to limit text length
How do you limit the length of variable generated text or force a second line after so many characters. Ie. I am using
<W@$SH_PART_NAME> for title block names but want to limit the length to fit into the title block space???
Chris
L&M Tool
RE: How to limit text length
Hi
Can't you just width adjust the text to fit in the title block space? There is an option to do this; it is the edit text (right click -> style -> Space Factor then enter 0.1 or something like that. Depends how much longer the text is in relation to the space... Or Failing that try Style -> Fit methods -> check 'auto size row' box. Then if you enter a load of text into a small box it gets 'squashed to fit'.
Rob.
If you're entering text into a 'cell' of a Parts List or a Tabulated Note, there are 'fit' options which include everything from changing font size to truncating long strings to automatic abbreviation.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
You could adjust the aspect ratio of the text style.
You can write a simple GRIP program that will truncate an attribute to a preset length.
attr1=substr(system_attr,1,x-char#)
Ben Loosli
