Applicable ASME Bolt Material for -36¦C/ >193.3MPa
I am looking for a suitable ASME setting bolt material for down to -36°C. Additional load from Piping appeared and now strength value of material SA 307-B (160 MPa) is not sufficient any more. Anchor Ring fabrication is already finished, therefore we do not want to modify it.
Does anybody know a suitable material with strength value higher than 193.3 MPa which can be used at Temperature of -36°C?
Thank you.
Thank you.
RE: Applicable ASME Bolt Material for -36¦C/ >193.3MPa
Am I missing something here?
Paul
www.ostand.com
Thanx, Chris
