create new parent error
UGNX6.0.3.6 / XPSP3 / 32Bit
When i try to use 'create new parent' i get the following message:
A dimension subscript for an array attribute was out of range or invalid.
What is the problem?
kukelyk
RE: create new parent error
Contact GTAC or your local support.
The file is stored in wherever UGII_TEMPLATE_DIR is pointing, and will have a .pax extension. If you are working under Teamcenter, the file name will start with nxdm_ something.Hope this helps, it's a bit arcane, I know.
Great! this was the problem. previously i cleaned this pax file, i left only the blank part template. thanks!
kukelyk
