Contact modeeling
Contact modeeling
Hi all,
I am modeling an insertion of a solid pin to a mandrel-specimen assembly. specimen has a central hole and mandrel is inside the hole. Pin will be pushed down in the hole which is drilled in the mandrel.
I've defined two pairs of contacts, pin-mandrel and mandrel-specimen. I've used both normal and tangential contact between the surfaces. and then I run the model and get some results. But it seems that the stress distribution is not correct in the specimen. I just get to regions of stress and strain in the specimen and I'm sure that it's not correct.
I've attached a drawing of my problem. In the drawing 1 is the pin, 2 is the specimen and 3 is the mandrel.
I'm using isotropic tangential behavior with penalty friction formulation and nonlinear normal behavior with constraint enforcement method of penalty(standard) for both contact pairs.
Can anyone kindly help me with this?
RE: Contact modeeling
Rob Stupplebeen
Thanks for your reply. I tried to remove aoverclosure by toggling on the "Adjust only to remove overclosure" in edit interaction dialog box. But it didn't work and I still get almost the same stress distribution in the specimen. Is it the right way to remove overclosure?
As you said, the geometry of my model is axisymmetric.
On top of that, when I increase the diameter of the pin to have a higher diametral interference, the solution will be aborted due to errors!
Any suggestion is highly appreciated.
Rob Stupplebeen
But now I have another problem. I need to model slip between the mandrel and the specimen when I rotate the mandrel. I change the shear stress limit or elastic slip parameters but there is no change in my model. I should mention that the specimen at the beginning of the rotation is in plastic region and s33 has exceeded the shear stress yield.
I expect that the surface of the hole rotates with the mandrel until slippage occurs. It's not happening in my model now!
Rob Stupplebeen
Rob Stupplebeen
Rob Stupplebeen
Rob Stupplebeen
Did you intend to the the indenter to have a dimple in the center?
I hope this helps.
Rob Stupplebeen
