Drawing Scale
Drawing Scale
Drawing Scale
We recently upgraded to 2001 and I can't figure out how to change the drawing scale since they removed the modify command. I'm not refering to view scale, that I have done. I want to change the overall drawing scale. How do I do this?
Ken Johnson
ITT Industries, Engineered Valves
RE: Drawing Scale
I don't know if this is the best way, but it works. Go to APPLICATIONS>LEGACY. DRAFT will give you the picks, including MODIFY. You can click on it and modify the drawing scale.
Oxana
RE: Drawing Scale
would you like to change view scale?
Then try with this, View - Modify View - view scale - select view to change the scale.
Or
Select View - Modify view - selct view - then change the view type from no scale to scale.
Yogesh
RE: Drawing Scale
#Edit #Value
RE: Drawing Scale
to change overall drawing scale in 2001:
choose EDIT:  VALUE: then in the lower left of the screen,
where it tells you the scale pick that text, and it will
pop up a window where you can enter what you want
