Horizontal Construction Joints in Concrete Walls
What types of restrictions do you usually put on the placement of horizontal construction joint in basement walls or interior shear walls? It seems that requiring a Class 'B' tension splice of your reinforcing bars and requiring the concrete surface to be roughened to a 1/4" amplitude would accomodate your flexural and shear requirements, respectively. But what if the contractor is locating two construction joints within the development length of the flexural reinforcement, say a joint within ld from the bottom of the wall? Thoughts?
RE: Horizontal Construction Joints in Concrete Walls
