Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Keep up the good work - excellent site - i'd been looking for something like this for ages !..."
Geography
Gloss and Smoothness Specifications for Paint
wchowe (Mechanical)
6 Aug 09 13:47
How do I specify smoothness and gloss of a painted surface. Are there GLOSS numbers? What about smooth? Can I assume, because a surface has a certain gloss it must be smooth?
Bill
CoryPad (Materials)
6 Aug 09 14:52
Yes, there are gloss numbers.  Standards for this include ASTM D 523 Standard Test Method for Specular Gloss and ISO 2813 Paints and varnishes -- Determination of specular gloss of non-metallic paint films at 20 degrees, 60 degrees and 85 degrees.
http://www.astm.org/Standards/D523.htm
http://www.iso.org/iso/iso_catalogue/catalogue_tc/catalogue_detail.htm?csnumber=7810
Here is a typical device used to measure it:
http://www.byk.com/instruments/products/7_1_US.php
For smoothness, you will need to consider multiple criteria.  Roughness, waviness, lay, and DOI (distinctness of image) may be involved.  There are multiple techniques, standards, instruments, etc. available.
You may need to contact some consultants, test labs, and vendors for help.
wchowe (Mechanical)
6 Aug 09 15:13
My vendor is telling me that he is supplying a GLOSS-95 finish. I hate to put something (like GLOSS 95)on a print without knowing what it is or how it is verified. So, I would have to buy these standards to know what GLOSS-95 means? Thanks for the help!
Bill
IRstuff (Aerospace)
6 Aug 09 16:43
Perhaps like here: http://www.genesiscoatings.com/PDFs/TECH%20SPEC%20-%20GCP%201000.pdf
ASTM D523 describes a 100-scale gloss value, but requires an angle as well.
TTFN
dik (Structural)
10 Aug 09 6:51
It is my understanding, the materials added to reduce the gloss also tend to reduce the corrosion resistance of a coating. Materials with a high gloss generally have a better corrosion resistance.
Dik
wchowe (Mechanical)
10 Aug 09 8:59
Okay, so GLOSS:95 @ 60 degrees. So the device that measures it at 90 degrees is at the same angle. I seem to remember (from Automotive) that painted surfaces were specified as Class 1,2,3 where Class 1 was the exterior of the car, hi gloss and no scratches allowed. Is that just automotive?
Bill
IRstuff (Aerospace)
10 Aug 09 14:55
I'm sure that every industry, auto, and paper, etc, have their own tribal approach to the same general problem.
TTFN
Close Box
Join Eng-Tips® Today!
Join Us             Close
