Swing check rating
Swing check rating
I was asked to make sure that a swing check used in a project could handle working pressure of 70 psi and flow rate of 65 GPM. The manufacturer gives me a pressure rating of 200 psi for water. Sounds dandy.
However, if that swing check closes, flow rate becomes zero and the pressure pushing back on it would be determined by how much water is above it in the system. Do I even care about working pressure & flow rate or do I just base it on pressure head? Am I just overthinking this?
Thanks!
Thanks!
RE: Swing check rating
I THINK YOU WILL FIND YOUR ANSWER IN THE THREAD BELOW
http://www.eng-tips.com/userinfo.cfm?member=sheiko
Did you mean: thread408-245080: Non-return (or check) valves process specification?
Patricia Lougheed
"Somebody on this Internet forum said it was ok" is not a sufficient explanation when responding to a lawsuit.
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
