How do you convert a surfaced iges file into solid - Solidworks 09
I'm dealing with a complex curved Iges file. When I import the file it comes in as a surface. How do I convert this file to a solid?
RE: How do you convert a surfaced iges file into solid - Solidworks 09
Have you tried Import Diagnostics?. Right-click on the imported feature in the feature tree to run diagnostics.
Dan
www.eltronresearch.com
Dan's Blog
Artem Taturevich, CSWP
Software and Design Engineer
AMCBridge LLC
www.amcbridge.com
Can you zip and attach or provide a url to the original IGES file here?
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
Fixing things is a subject to itself. We can help once you have specific problems.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
The header will tell you what system the IGES was created in.
An IGES and STEP file are plain ASCII test files which can be opened in Notepad.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2009 SP3.0, Windows 7 RC1
http://www.solidmuse.com
http://www.phxswug.com
IGES5.3 contains the full description of the header (global section) on page 18.
NIST also has something on this.
TOP
CSWP, BSSE
