Bearing Life
Bearing Life
I've checked around looking for a way to calculate the bearing life of a sleeve bearing without luck. Basically, I have a cold rolled steel axle, a bronze alloy sleeve pressed into a steel wheel which will fit around the axle. The velocity is +/- 45 feet per second. Can someone suggest a reference?
RE: Bearing Life
http://www.tribology-abc.com/calculators/
