Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just to let you know...what a great site you have. I posted a pretty generic question yesterday and have had 8 responses already, anyway thanks again and keep up the good work..."
Geography
Apakrat (Civil/Environmental)
5 Aug 09 20:09
I have a working knowledge of geometry, algebra, and trigonometry but absolutely nothing about calculus.
Usually, when using metrics, I convert to feet, gallons, etc to be comfortable because this "SI" is almost baffling if it were not for a couple of conversion tables found on the Internet.
I need to calculate the Theoretical Horse Power at the horizontal shaft axis of a waterwheel being propelled by the flowing force of river water against the paddles of the waterwheel.
The animated image below is supposed to represent a Elevation view of a waterwheel in flowing water.
Quote (Formula):
F = MA2 ÷ 2
    F = power in ft-lb/sec
    M = moving volume in lb/ft 3 ÷ 32.2 lb/slug
    A = flow rate in ft/sec
F ft-lb/sec X 60 sec/min = F ft-lb/min
Theoretical Power (hp) = ( F ft-lb/min X  rpm ) ÷ Factor 5252
Is my understanding of the Formula logical?
Ignoring wind, water surface ripples, impure water, temperature, and mechanical efficiency, I calculated a 12 ft. diameter waterwheel with 3 ft wide paddles, in a river flowing at a rate of 6 ft per second, will develop a 68.5 Theoretical Horse Power at the waterwheel axis shaft rotating at 9.55 rpm.
At 74th year working on IR-One2 - - UHK PhD - - -
cpretty (Mechanical)
5 Aug 09 22:28
A first comment is that the wheel will not rotate at 9.55 rpm while the shaft is loaded.  To get any useful work out of the wheel, the wheel will travel slower than the water.
There will be a relationship between torque available and rpm range from high torque (not maximum) at 0, and no torque at 9.55rpm.
I will attempt to comment on the rest of the calc but am the opposite and need to convert to SI to even comprehend the problem.
7 Aug 09 12:06
Thank You "cpretty"!!
Have personally been concerned about the rpm thingy. I couldn't find a formula showing a ratio to the rpm.  Maybe it was in the calculus formulas which I couldn't comprehend.
Perhaps this is a better arrangement.
Quote (Altered Formula):
Theoretical Power (hp) = (  F ft-lb/min X 1/2 rpm  ) ÷ Factor 5252
I must apologize for failing to include metric equivalent of values used, with initial posting.
        12 ft (3.6576 m) diameter waterwheel
         3 ft (0.9144 m) wide paddles
         6 ft (1.8288 m) per second flow
        68.5 Theoretical Horse Power (51 kw)
Am I getting closer???
7 Aug 09 17:25
Thank You "IRstuff"
I went to the link suggested which has an article written by "Rudy Behrens".
Played with the mathematics, along with the same numbers in formulas given at
All three have slightly different formula arrangements but  the final numerical results are almost identical.
They all calculate about 10% more power than my initial formula as first posted above, which is based on Newton's law and torque power conversion to angular rotation.
Quote ("Rudy Behrens"):
"The most efficient energy transfer occurs when the wheel speed is between 67% and 90% of the water speed."
Curious!!        Curious!!        Curious!!
FeX32 (Mechanical)
10 Aug 09 22:13
I don't see where you take into account the number of blades in the water at any one time. There are many assums.
Although, I don't see any major concern with the original equn.
BUT, personally, I would never trust a formula I haven't derived myself unless it was for a very good reason. I always feel better about a problem when I start from ground up....
For example, I may start by simplifying the problem so it has only one blade completely vertical and draw a conclusion using conservation of momentum. Then find out what may happen when we add more blades.
peace
Fe
BigInch (Petroleum)
11 Aug 09 12:24
http://www.panoramio.com/photo/8214845
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
GregLocock (Automotive)
12 Aug 09 3:53
Would your equation show a 33% benefit if the blades were curved? If not, it doesn't seem very useful, since that is a real test result.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Close Box
Join Eng-Tips® Today!
Join Us             Close
