SLC 5/05 help
SLC 5/05 help
SLC 5/05 help
Hello everyone.
I'm not overly familiar with PLCs.  I know how to read through them and adjust them and do some minor programming, but other than that, I'm new to them.
Anyway, I've been sent to a jobsite, to correct a few mechanical issues and one PLC issue.  I've used the ladder logic at this job site - I was actually the first one to upload it - many times without issue, so I know the processor and laptop are compatible.
Most times I travel with a programmer or I have the code to just upload.  This time though, I need to get on to the processor, download the current program, and change one line in the code.
My problem is, that I cannot get my laptop to recognize the processor.  It keeps looking for the last project I worked on (different site all together) and coming back with a "No response from processor" error.
I've done some searching online, and I'm going to go through this webpage tomorrow:  http://engineer-and-technician.com/connecting-to-an-allen-bradley-slc-and-going-online/
Just wondering if there is something simple I'm overlooking or if there is a more complicated issue causing this problem.  Normally I'd be able to call back to the office, but the only one who would know is away and not available (hence sending a virtually useless programmer to site).
Cheers and thanks for any help.
RE: SLC 5/05 help
Can you see the SLC in rslinx?  Or does it have yellow ? or red X on it?
If you can see it in linx the in rslogix 500 go to comms>>system comms>>who active  highlight the SLC and select Online.
RE: SLC 5/05 help
I have two things that show up in RSLinx.  I'm not sure what either of them are.  One says Linx Gateway and the other is AB-ETH-1 Ethernet.
RE: SLC 5/05 help
Each of the things found has a red X through it too.
RE: SLC 5/05 help
just wanted to say I've figured it out.  Thanks for the help.
Sometimes typing it and thinking about what I'm saying helps me out.
Cheers.
RE: SLC 5/05 help
So, what was it?
RE: SLC 5/05 help
Simple.  The IP address I had was wrong.  I went through the program I had running in Jan and found the IP address.  I then used the IP address when configuring a driver in RSLinx.  Worked right away.
Cheers.
