A lesson on tolerances...
Preface: not quite a structural topic but a construction one so it seems like it fits here...
http://s eattletime s.nwsource .com/html/ localnews/ 2009599889 _portmista ke05m.html
As a side note, somebody on another forum points out that 2.52" is 64.008mm which means someone quite possibly converted from metric and dropped a bit of precision...
http://s
RE: A lesson on tolerances...
- If this was important the cable could have been procurred in less time.
- 2/100th of an inch =slightly more than 1/64th of an inch off. To mitigate the problem its hard to believe they couldn't have made use of the larger cable.
- Its a quasi government job ie results not as important as process
These, of course, are opinion, but this story has me slightly upset.
Incompatible tolerances. Absurd.
Mike McCann
MMC Engineering
It's a cable at the end of the day.
BA
Unless of course this is cast in place steel...
Anthony Deramo
American Bridge Company
If the company said a 64 mm trench and I gave them a 63.5 mm trench, do they have an argument? (Perhaps 64 mm, min)
Can't those problems usually be fixed with a big hammer? (Particularly in this case!)
-- MechEng2005
This is what happened when engineers/scientists read the news.
