Possible simple question re: extrude limits (NX5)
Where are the default values for the start and end distances stored? I have no idea how the current default values were established, and I'd like to change them. I skimmed through preferences and customer defaults but didn't find anything.
TIA
TIA
WinXP-SP3 / NX5.0.4.1 MP6 / Catia V5r18 / NX I-deas 5.3.0.14
RE: Possible simple question re: extrude limits (NX5)
Note that once you start making changes to these values, the system, via the Dialog Memory scheme introduced in NX 5.0, will remember and retain your last values set until you change them again, or you select the 'Reset' button at the top of the dialog, which will return the dialog settings back their original OOTB values.
Also note that unless you have disable this in Customer Defaults, the system will automatically retain the values of most all dialog entries not only for your current session, but will also retain the last used values when you launch your next session of NX so in reality the original default values become irrelevant once you realize that what is being shown to you are the actual values (and option settings) as you yourself used the last time you executed that particular function.
Therefore, starting with NX 5.0, the values of the Feature Parameters (as well as most other option settings) seen in most NX dialogs ONLY represent the system/customer default values when you launch NX the first time after installation or whenever you explicitly 'reset' a dialog. In all other situations, the parameter values merely reflects your last usage of that dialog.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
It's a minor inconvenience, though, so I'm not worried about it. I was just hoping there might be a way to set them myself.
Thanks again.
John R. Baker, P.E.
Industry Sector
Cypress, CA
