lines(edges) dont change color when selecting them
For example. When you are about to select a line to dimension, it used to turn red before you selected it to ensure that was the line you were selecting. Also, in a model, when I go to select a edge to add a radius to, I can tell which line im selecting until after I select it. It does not change color when you place the pointer over the edge like it always has. How do I get this back? Ive tried everything I can think of. Ive gone thru the filters also. Im running 2007 sworks.
thanks guys for any help.
RE: lines(edges) dont change color when selecting them
Flores
thanks for the prompt help guys.
-handleman, CSWP (The new, easy test)
