AL 6XN Clad 2:1 Elliptical heads
is it possible to form a head using carbon steel plate with AL 6XN clad material or is the clad material typically added by welding?  Are there any tank heads manufacturers that do this?  I am getting alot of no quotes.
Thanks.
RE: AL 6XN Clad 2:1 Elliptical heads
Yes it is possible.  The two head fabricators I trust for this particular job would be Brighton in Ohio and Antonius in the Netherlands
In re to MJ note:  DMC makes the clad plate by explosion bonding, but does not make heads.  Ametek makes roll bonded plate, but not heads
