Full face gasket
Full face gasket
Could anybody recommend any proper full face gaskets to apply to 150# flat face cast iron valve with 150# flat face flange till temperature 400 degree F?
RE: Full face gasket
Just a note, cast iron valves are class 125 and 250. You might have a ductile iron valve, or a cast steel 150 with the raised face machined-off. You may want to double check the valve.
