pressure-tight bearing?
I have a large steel pressure vessel at 100 PSIG with gases inside. Gas temeprature might be as high as 600 degrees F.
I need to pass a long ceramic rod, perhaps 1/2 inch diameter, through the side wall of the vessel. I am looking for a bearing that can hold the rod at the vessel wall, allow it to rotate, but be gas-tight. Rotation rate will be around 10 RPM.
Any suggestions?
Thanks for the help.
Rich
Any suggestions?
Rich
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
RE: pressure-tight bearing?
Let us know what solution works for you!
Good on ya,
Goober Dave
