Moisture Analysis of Polymers
Would anyone know where to obtain recommended setting (Drying Temperature & Drying Time) for carrying out moisture tests on polymer resins (PC, PA 6, PA 11, PA 12, ABS, Pebax's etc)
JPC10
JPC10
RE: Moisture Analysis of Polymers
Chris DeArmitt
"Knowledge has no value except that which can be gained from its application toward some worthwhile end."
Think and Grow Rich - Napoleon Hill
http
Chris DeArmitt
Weight program automatic
Time 20 minutes
Temperature Tg of the polymer plus 20°C
Chris DeArmitt
A lot of laboratory set-up and library data on this subject (including referenced moisture figures for various virgin, filled and composite materials) can be found at http://wwww.composite-agency.com
You may also try their forum on integrated knowledge of diffusion, corrosion and mechanical retention properties
(h
Kind Regards,
Rodney
