Screw compressors intermediate pressure estimation
I'm trying to create an excel sheet where I can simulate screw compressor but I can't understand how to estimate intermediate pressure.
I've tried using pi=(p1*p2)^.5 with no results.
I've also tried using intermediate Vi without success.
pi=p1*Vi^k
The situation gets worse if I try with partial load where intermediate pressure is close to suction pressure (because of slide valve opening).
Is there any equation???
Thanks in advance
RE: Screw compressors intermediate pressure estimation
You might look through some of te work by Stosic at City University of London
Thanks for the suggestion.
Those books are too expensive... and I only want the equation...
Using compressor manufacturer' software I drawn two diagram:
- suction pressure (x) vs intermediate (y)
- discharge pressure (x) vs intermediate (y)
and in both of them I found that intermediate pressure is linearly dependent on them...
I think that the equation could be
pi = a*p1 + b*p2 +c
The drawing shows that a>>b,
but I have no idea on their values,
and I have no interpretation of real mechanism...
Bye
