Momentum analog IO configuration ?
There is a block to configure for analogue IO for the 170-aai-030. The block is calle ANA_8I I understand what to put in the parameters but I don't understand what value to put in the first parameter called IBS_IN I'm guessing it's the IO mudule position # but am usure of what that is or how to enter it in a fashion the block would understand.
My configuration is a CPU with 16 DIG IN 16DIG OUT on base, + AAI-030 + AAI-030 + AAO_120 + AAO_120. im using concept 2.2
