wind farm collection system
What would be the advantage to installing a 34.5kv collection system where the cables are kept seperated by a minimum of seven inches horizontally vs. zip tied together every 4 feet, or does it matter? This is at a wind farm. I have seen them done both ways. Of course the engineers who designed them aren't available for questioning. It seems that there shouldn't be a need for cross cancellation due to the generator producing a balanced load. I have heard that you can follow the buried circuit over snowy areas where they are zip tied as they heat the ground, I haven't been back to see it though.
RE: wind farm collection system
Consitering the installers point of view, it's just easer to zip tie the cables and not worry about transpositions.
Neher, J.H., and McGrath, M.H. (Oct. 1957), "The calculation of the temperature rise and load capability of cable systems," AIEE Trans., vol. 76, part 3, pp. 752-772
IEC Standard 287 (1982), "Calculation of the continuous current rating of cables (100% load factor)," 2nd ed., 3rd amendment, 1993.
Anders, G.J., Rating of Electric Power Cables, McGraw-Hill, IEEE Press, 1997.
