how can I test a 15 hp 3 phase motor without having power
Can anyone tell me how I can test a 15 hp 3 phase baldor motor. I do not have 3 phase power, but I do have a 5 hp rotary phase converter. I have multimeters, ohm meters ect.
RE: how can I test a 15 hp 3 phase motor without having power
Check the windings for continuity and balanced resistance, and megger the windings to ground at 1000Volts.
If it passes these tests, the odds are probably over 1000:1 that the motor is good.
Or, as David suggests, rent a generator.
Or, throw the motor in your truck and take it to three phase power.
Bill
"Why not the best?"
Jimmy Carter
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
