Heat Pump with CO2 as Refrigerant
I'm a new Aspen plus user and I would like simulate a Heat pump process with CO2 as Refrigerant. After I give all the specification and all blocks are with a blue color(completely specified).
My simulation get not started, I get always this Error:
Processing input specifications ...
INFORMATION
BINARY PARAMETERS PRKIJ (DATA SET 1) FOR MODEL ESPRSTD
ARE RETRIEVED FROM SDF TABLE. TABLE NAME = ESPRSTD
* WARNING
THERE ARE NO INLET STREAMS TO THE FLOWSHEET.
FLOWSHEET CONVERGENCE PROBLEMS MAY RESULT.
* WARNING
THERE ARE NO OUTLET STREAMS FROM THE FLOWSHEET.
Flowsheet Analysis :
Block $OLVER01 (Method: WEGSTEIN) has been defined to converge
streams: 1
COMPUTATION ORDER FOR THE FLOWSHEET:
$OLVER01 B2 B3 B4 B5
(RETURN $OLVER01)
->Calculations begin ...
> Beginning Convergence Loop $OLVER01 Method: WEGSTEIN
Block: B2 Model: HEATER
* WARNING
ZERO FEED TO THE BLOCK. BLOCK BYPASSED
Block: B3 Model: VALVE
* WARNING
Block: B4 Model: HEATER
* WARNING
Block: B5 Model: COMPR
* WARNING
TOTAL FLOW IS ZERO. INLET STERAM IS COPIED TO OUTLET.
SKIPPING REST OF THE BLOCK CALCULATIONS DUE TO INPUT ERRORS.
> Loop $OLVER01 Method: WEGSTEIN Iteration 1
# Converged Max Err/Tol 0.00000E+00
->Generating block results ...
*** SEVERE ERROR
FORTRAN INVALID OPERATION ENCOUNTERED.
*** SEVERE ERROR
the Blocks are:
B2 : a Heater( it has the function of a Gas cooler) specification: Pressure:100bar
vapor Fraction:1
B3: a Valve. specification: outlet Pressure: 100bar
B4: a Heater again (it has the function of a evaporator) specification: Pressure: 30 bar Heat duty: 100 kw
B5: Compressor, isentropic. specification: Discharge Pressure :100 bar.
can u help me please!!
thanks in advance.
INFORMATION
* WARNING
* WARNING
streams: 1
(RETURN $OLVER01)
* WARNING
* WARNING
* WARNING
* WARNING
*** SEVERE ERROR
*** SEVERE ERROR
the Blocks are:
vapor Fraction:1
thanks in advance.
RE: Heat Pump with CO2 as Refrigerant
you need to have a stream get in the first block with the definition of the stream composition and process condition.
Hope it helps
well now it's everything ok and the calculation were completed normally.
but i still have the problem with the plot wizard, so wenn i click on plot , then click plot wizard and after selecting a plot type then the next button, i usually get the answer "results not avalable"!!
i really dont understand, where is the problem??
please help me..
thanks in advance.
