Solidworks PCB model
I was wondering if anyone had a basic PCB Solidworks model with all of the "guts" on it.  I am putting together an assembly and want to insert a 3"x6" PCB model for illustrative (form and fit) purposes.
RE: Solidworks PCB model
You might want to talk to your VAR as well. Dan had the best suggestion.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 3.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Thank you rollupswx.........I was able to alter the model a bit to fit my parameters and it worked out great!
