Neoprene Latex/Austenic SS Corrosion
I am experiencing corrosion on ss contained within a neoprene latex protection boot. I'm not an expert, it appears like an intergranular crystal growth. The SS is not under tensile stress (perhaps some residual). I am speculating there are chlorides being released from the boot but there is little moisture available. Could crevice corrosion take place in this contained but "dry" environment? Has anybody else experienced this problem with a protective cover?
thanks for any comments.
RE: Neoprene Latex/Austenic SS Corrosion
If the attack looks like it is along grain boundaries then you should have a sample examined by a lab. It may be sensitized (not properly annealed) this greatly increases the risk of corrosion.
Plymouth Tube
If this part was not passivated, then yes, it improves corrosion resistance.
