Sand filter for pump suction
Hi All,
We have a pump, Q=30 l/s, Hm=350 m. Speed= 1450 rpm, for agricultral irrigation sucking sandy water from a river. The water is too sandy and our pump wears off too quickly. Are there any filtering system for sandy water to be installed on the suction pipe of the pump?
Many thanks in advance.
RE: Sand filter for pump suction
-Mike
In the end it comes down to the cost of a filter/settling tank vs the cost of higher grade pump materials.
That's a decision only you can make.
http://www.riverscreen.com/
Try e.g. http://www.seepex.com/
Got good service there once.
Best regards
Morten
