Storage tank design with API 650
Hi dear all,
I am a mechanical engineer.I work in gas & oil company. I want learn about "Storage Tank Design" (fixed roof and floating roof tanks). I am only in my job. Do you help me about this matter (for example a guide line note)? By the way I love this job.
Many thanks
Ahmad
RE: Storage tank design with API 650
Maybe is better if you use API 653 (inspection and repair), if your job is with tanks constructed already. API 650 is for design and construction of tanks.
If you can get your hands on either of the following books you will learn a lot:
Above Ground Storage Tanks - Philip Myers
Guide to Storage Tanks and Equipment - B Long & B Gardner
Good luck
