Local Stress at side a Big Valve
HI everyone
I have been desiging a water pump station, there are 13 pumps and the manifold is 60", also there a butterfly valve, its weight is around 3500 Kg, the manifold thickness is 3/8" and the system pressure is around 40 psig, according to my stress analisys with AutoPipe, there is not a significant stress and deformation, but i want to be really sure that the pipe won't deform by the weight valve, i want to calculate the local stress. Someone can help me?
César
César
RE: Local Stress at side a Big Valve
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
