Measuring Air Temp in Return vs On Wall
We have expanded our 400 seat auditorium to add an additional 200 seats (600 seats total). The expansion came with two additional HVAC units independently controlled by two additional thermostats. This appears to be a very poorly designed system. Our existing unit measured the return air temperature. The new units measure the temperature at the controls on the wall. Is there a code that states when return air temperature should be measured and when measuring on the wall is acceptable?
RE: Measuring Air Temp in Return vs On Wall
I think you really need to coordinate the work of the three units to get good comfort control, and this will require some controls work beyond just three thermstats and their placement.
Post us with your solution!
Good on ya,
Goober Dave
