"impulse piping"--could anyone tell me what "impulse piping"
I'm trying to translate the term "impulse piping" into Japanese.  I've tried by entering these keywords like "impulse", "impulse, piping, transmitter", including this "impulse piping", and couldn't find any translation.
I know this is not a place for asking translation...
This quotation is kind of close to my text;
"CAUTIONS ON IMPULSE PIPING For liquid, the impulse pipies sould have an upward slope of 1/10 or more between the process connection and the transmitter to prevent accumulation of gas, etc..."
I think this "impulse" means a type of transmitter which uses pulse signals to measure gas/liquid flow.  But have no idea if "impulse piping" is kind of a verb or it should be translated like "how to connect === pipe to transmitter" or whatever.
Or is "impulse" have something to do with the magnitude of these flows??
RE: "impulse piping"--could anyone tell me what "impulse piping"
Anns!
Impulse piping or Impulse tubing is generally used in instrumentation. When your service fluid is hot, it may create problems to the electronics circuitry. These are basically used for DP type transmitters. These are the piping which connect the instrument to the piping. If you want further information better contact Fischer Rosemount.
Truth: Even the hardest of the problems will have atleast one simple solution. Mine may not be one.
Thank you very much for your kind help.
I think now I got a picture about these "legs" which connects the transmitter to the main process line.
thank you!
