LPG STORAGE AND HANDLING FACILITES
HI,
my question is about LPG storage facilities(high capcity)
what is the greatest capcity for lpg storage and handling facilities that can be constructed and what type of tanks is the most appropriate,
if possible examles over the world
I need informations about this topic please
thank you very much.
RE: LPG STORAGE AND HANDLING FACILITES
The next largest containers are refrigerated low pressure tanks that can reach 50,000 bbls. The operate at 10 psig or so.
More typical are high pressure tanks that operated at 250 psig. they are typically 30,000 gallons to 120,000 gallons.
Some local jurisditions only ally a limited number of tanks in one area. You may only be able to have 240,000 gallons together and then another set of tanks with 100 to 200 feet of seperation.
