mode shape
mode shape
mode shape
i have 3D model for entire structure. Not an FEM model expert yet. I need to find out frequency of local area. Is there an easy way to find out which mode shape governs?
RE: mode shape
Look at mass participations for each mode.  If mass participation is low (5% or less), you probably have a local mode.  Then, look at the mode shapes.  Amplify deflections until you see the local area that you are interested in deflecting by itself.
RE: mode shape
I should be able to get rid of the local mode by increasing the member stiffness. Am I right?
RE: mode shape
You should be able to change the frequency of the local mode by increasing the stiffness.  It may no longer be the 1st mode...or a specific mode number as you may be able to drive the frequency out of the range of concern.
