BSPP to NPT plastic fittings
Looking for a way to go from a 2" female BSPP ( G ) thread to a male 1" NPT thread.  Ideally, it would be a combo reducing/thread type.
The ideal fitting would be 2" Male BSP to 1" Male NPT.
Any suggestions on where to find this?  I've tried all of the usual sources ( Grainger, Cole Parmer, etc ).  No luck.
Ideally it would be plastic, but if they are just plain steel, that might work too.
Thanks.
RE: BSPP to NPT plastic fittings
A block of nylon, a lathe, a 2"female BSPP tap, a 1" male NTP tap. and the appropriate size drills. You can look them up in a chart yourself.
If you want to do it in a pedestal drill, use a female 1" NTP tap and a 1" NTP nipple.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Try your local Swagelok distributor.
Mike Halloran
Pembroke Pines, FL, USA
Thanks, Pat.  That's what I figured it would come to.  I have a small machine shop helping me out. They do this kind of work in the specialty valve market.
I can find a 2" BSP male, but not one in plastic, and they start around 65 bucks each.
I think what will work best is a 2.5" piece of plastic rod, threaded down on both sides and leaving a 1/4" ORB for the BSP seal.  The through hole needs to be 3/4" diameter.
Thanks again.
My bad on "plastic" ... haha!  The rest of it is polypropylene.  It doesn't matter to much as long as it's able to withstand urenthane chemicals ( polyol and isocyanate ).  Nylon, Delryn, whatever is cheapest and has no issues with those two families of chemicals.
I would think all would be OK with urethane systems.
Acetal (Delrin) is best at holding threads unless the temperatures go over 70 or 80 deg C when nylon will take over. Neither like exposure to acids
Pat
for site rules
No one has what I need in any type of plastic.  I'm having them made by a local shop, a 2" male BSPP thread on one side with a o-ring groove and boss, and 1" male NPT on the other side with a 3/4" hole through the entire piece.
Thanks for all the suggestions.
