Ambient Temperature Adjustment Question
3
Designing some motor feeders that are routed in rigid steel conduit on an outdoor piperack.  I am confused as what to use for the ambient temperature to determine if ampacity adjustment is required.  Should I use the warmest average summer monthly high temperature, the areas record high temperature record, or other.
RE: Ambient Temperature Adjustment Question
3
Where are you located?
The project is located in San Antonio.  The motors are large 480V gas compressors and vacuum pumps.
NEC 310.15..2.c (2008) applies to roof installations but may offer some guidance.
Alan
"It's always fun to do the impossible." - Walt Disney
deedo1124
How about a response.
Wareagle
Thanks for the link.  This will be very helpful.
