ABB Procontic T320/V8 PLC
I'm trying to configure this PLC but,when I follow the steps in the procedure it tells Me that it must be Cold Started from the beginning. When I do this it gives me the following error. (Transfer not accepted) I was wondering if anyone has any suggestions.
RE: ABB Procontic T320/V8 PLC
Well best guess is that the hardware thats out in the field does not match your configuraion.
Your processor does not match your configured processor.
You need more memory in that plc.
But I only work on AB and siemens.  But most problems are the same.
